LOTW 2.3 download speed
Re: LOTW 2.3 download speed
That makes a difference.
So what is WARN: MULTIPLE QSO UPDATED:
Apparently it does not remember that check mark?
V1 you never had to mess with it as the QSL received since. Is that planned for future?
NN7D
Post by NN7D »
Duane,
I am checking this. For some reason on the second LotW download attempt, the Received Since date is unchecked, and that is causing the download to take much longer, as its likely going through the complete LotW records for new confirmations. Workaround for now, recheck the Received Since date...
Good catch!
Doug - W7DRM
W7DRM wrote: 03 Feb 2020, 22:02 Duane,
Good catch!
Doug - W7DRM
No doubt
17:21:46: ADIF FULL document parsed: 6831 qso found.
ac5aa
Post by ac5aa »
Thanks, Doug - after Terry's response, above, that is what I've been doing. I agree, if I select "last download" it should not try to do the massive downloads, only the "latest" confirmations. At least, that's what makes sense to me.
73, Duane
73, Duane AC5AA
