You may unpacking this one and save it in the Omnirigs Rig folder where the other Rig .ini
files are stored. I have called it FT891_Log4OM.ini. It may working but i´m not shure. Try
and find out. I don´t have one of those Yaesu Rigs.
Omnirig reporting radio in SPLIT when it isnt
Re: Omnirig reporting radio in SPLIT when it isnt
Thank you for fast reply!
The file is not working. There is not any change between VFO A/B and RX/TX.
But now by pressing "\" key, transceiver toggle TX and won't get back to RX mode anymore (until power off). With old FT981.ini file there wasn't any issue with RX/TX mode.
So, I'll back to old file for now and still looking for a solution.
Hi, in my first post on this forum.DF5WW wrote: 24 Nov 2020, 17:29 You may unpacking this one and save it in the Omnirigs Rig folder where the other Rig .ini
files are stored.
I used find function with command "*Log4OM.ini" on c: drive ( only one hard drive is installed ) but cant find others files.
Has there been any new solution to this error since the last post?
Yaesu FT-891 Longwire & CG3000
You must store the unpacked file in the Omnirig folder where the .ini files for the radios
are saved. Has nothing to do with any Log4OM folder. Omnirig is a seperate software that
is used by Log4OM for the CAT connections.
I have the same issue with Omnirig and the FT-950. I found that if I open the OmniRig app and leave it open, then restart Log4OM, the problem goes away and Log4OM displays accurately.
Please check that all programs running as administrator. Set Log4OM to use Omirig (no possibility to
open it extra or leave it running). Open the .ini file in the Omnirig Rigs folder with an editor and
change the values for split on and split off. Then try again.
My edit of the FT-950 ini wasn't successful, but setting the rig type to FTDX-3000 gives me a working configuration. If I was ambitious I'd cut/paste the split setting from the FTDX-3000 into the FT-950 ini, or simply make a copy of the entire file and rename it.
