SpotCollector has always worked regardless. Log4OM seems to be working now, after adding the SH/DX line. Coincidence, maybe? I don't know. Just another reference point.
I must mention again this issue is present only with FT8. The 'suspicion' is that Log4OM does not handle the 'avalanche' of spots very well.
For FT8, the RBN is a better choice, but I still cannot make that work properly. The number of FT8 spots there is greater than VE7CC.
NT6X wrote: 26 Feb 2020, 18:35 If you're using VE7CC as your node, it's best to log into VE7CC using the CC Cluster program (http://www.bcdxc.org/ve7cc/) and set your filters directly at the server level. Then log back into Log4OM and your filters are set the way you want them. There are many more filter option to suit your needs with only a few mouse clicks.
