Because if you lookup most French stations on QRZ they don't add it to the state field
This is why we don't use the state field for that award, instead we use the DDFM ref number so like DDFM-95
Award DDFM
Re: Award DDFM
Re: Award DDFM
Hello Terry So if I understand correctly it is impossible to have directly the reference code DDFM like the dxcc if I enter a French qso I have to enter it manually each time I do it?
Damage to be expected at the next modification .
F5PLR Didier
F5PLR Didier
Re: Award DDFM
I confirm that you must select the award manually during or after the QSO it cannot be automatic because the departments cannot be downloaded because they are not usually found in the state field.
