Page 2 of 2
Re: ISSUE IN UPLOAD CONFIRMATIONS LOTW
Posted: 14 Jun 2021, 05:13
by xe1aca
Hi Hams
I went back to 2.13.0.0 and the issue of uploading to LOTW completed. I think there is a bug in the new version(2.14.0.0) since after I updated I started with the problem.
I´m use JTAlert ver. 2.16.17
Regards 73"
Posted: 14 Jun 2021, 05:16
by xe1aca
n0iai wrote: 14 Jun 2021, 00:07
Same issue, rolled back to 2.13.0.0 LOTW uploads complete.
Posted: 14 Jun 2021, 05:18
by xe1aca
G4POP wrote: 13 Jun 2021, 09:44
HB9DBM wrote: 13 Jun 2021, 08:57
Hello again,
I just tried to upload to LOTW withon LOG4OM using QSL manager.
This is broken too.
Again, if I generate a ADIF for the selected QSO's and upload this ADIF using TQSL.exe , there is no issue. Works fast an reliable
Are you using Gridtracker?
Hi Hams
Posted: 14 Jun 2021, 07:12
I suggest that you send a support request to Lele because none of the Alpha testers or I can replicate this issue so it has to be local to your setup.
Posted: 14 Jun 2021, 10:50
by KI5IO
Have y'all considered trying to run your FTxx APP (JTDX or WSJTx) on a direct connection to Log4OM V2 as a test to see if the issue persists?
Meaning ... take JTAlert out of the loop?
Set up the direct connection as outlined in the most recent User Guide.
Give it a test and see what your results may (or may not) be.
Just a simple trouble-shooting technique ... simplify the installation one step at a time.
Posted: 16 Jun 2021, 14:33
by w0jd
KI5IO wrote: 14 Jun 2021, 10:50
How is JTAlert "in the loop" when performing a manual upload to LOTW?
Posted: 16 Jun 2021, 16:13
n0iai wrote: 16 Jun 2021, 14:33
It's not but sometimes the QSO information arriving from external software contains the wrong information which when applied to a LOTW upload causes a problem..
Posted: 04 Nov 2021, 18:03
by WH6A
FWIW I get similar behavior when a log mismatch with LOTW station location data occurs.
Ex: log contains grid EL99ki LOTW station location specifies grid EL99lb
Start the LOG4OM2 upload and get:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.8
No private TQSL Password set
Executing TQSL with upload
Then nothing happens, (waited overnight at least once) so force quit Log4OM2 upload
I troubleshot the issue by performing a manual upload of the same log using TQSL GUI and it returned error messages specifically stating the mismatched field issue.
Updated LOTW station location grid to match log and all is working fine with LOG4OM2 uploads to LOTW
