Page 2 of 2
Re: LOTW Upload Fails When Require Log (Version 2.16.0.0)
Posted: 23 Aug 2021, 14:43
by ct1hix
Hello Nolan
The answers:
-Yes, the problem started with the new version. It always worked well.
-It was an upgrade
-Yes I have the latest versions installed
-I'm just search for unsent by LOTW "NO"
-I don't think there has been any change but I'll check it again... again and again!
I must be making a mistake but I don't understand which.... I have always uploaded successfully.
Thank you for your help
Gomes CT1HIX 73
Posted: 24 Aug 2021, 19:07
by ct1hix
I use two callsigns ea1/ct1hix (and /p) and ct1hix (and /p)... I've never had any problems but now it looks like there's something that doesn't work the same way.
The ea1/ct1hix/p and ct1hix/p logs are imported but I always upload this logs.
All the qsos I want to upload are with the callsigns EA1/CT1HIX/p and CT1HIX/P
I simulated with a qso registered directly in Log4om and everything works ok
What will be happening?
Tks
Gomes CT1HIX 73
Posted: 25 Aug 2021, 01:57
by DF5WW
Did you use different configurations for these calls and if yes, have you the correct certificate (LotW)
in the setups for each configuration ? The configuration for call one or call two are active if you try
to upload ? One of your certs are expired ?
Posted: 25 Aug 2021, 22:20
by ct1hix
Hello Juergen
No, I only have one configuration. CT1HIX and EA1/CT1HIX certificates are ok.
I also have to have certificates for the /p operation?
I don't know how, I have a few thousand qsos identified as "sent", which should have been an error...!
I have to do a careful analysis to understand what happened and what was the result of so much nonsense.
Gomes CT1HIX 73
Posted: 26 Aug 2021, 06:49
ct1hix wrote: 25 Aug 2021, 22:20
Hello Juergen
Gomes CT1HIX 73
What exact version number of TQSL are you using?
Have you checked the settings in Log4OM program Configuration to ensure the temp path is set and that the station location matches the TQSL station location.
Have you looked at the log files to see what response there was during the attempted upload?
Screen shots always help us understand an issue!
