Think your running an old version of tqsl it should be .
Build 2.6.2
Library 2.5
Configuration 11.20
Try updating and see what happens
Log4OM-2 V 2.19 LOTW locks up on close
Re: Log4OM-2 V 2.19 LOTW locks up on close
I just checked it and I am running 2.6.3 and Config Data ver 11.20. It shows as "Current Release". If I do an ADIF export and then upload it with TQSL it works great. I don't understand what is keeping Log4OM from finishing this and closing properly. I checked my Activity in LOTW and my QSOs are uploading correctly and are current to the last time I closed Log4OM.
Thanks!
Rory Bowers, K5CKS
Thanks!
Rory Bowers, K5CKS
Rory,
Changes were made in Log4OM with V2.20.0.0 regarding some LOTW output parameters.
I would suggest you d/l and install V2.22.0.2
I just completed a 30+ QSO upload to LOTW without any errors following today's SST event.
I'm also using the same version/release of TQSL as you are.
Re: Log4OM-2 V 2.26.0,0
Uploaded the new version about 2 weeks ago and a few times when I click a call from the Cluster window I get Refreshing. Takes sometimes 20-30 seconds. But other times I will get a message saying the call is invalid and the program locks up. It freezes the computer and I have to a Ctrl/Alt/delete to get shut down. I went into task manager and when LOG4OM gets a call sign put in from the Cluster the power usage on the computer goes to very high, then to moderate and then to low. This happened again today when I click on a call in the cluster and had to get restart the computer. running Win10, I5 @3.30GHZ - 8 GB Ram. It never happened from the previous LOG4OM. Yes, my TQSL is up to date.
Tnx, John
ND1X
Tnx, John
ND1X
