Re: After updating Log4OM 2.18 to 2.25 OmniRig is blocked (by Log4OM) for other applications
Posted: 26 Dec 2022, 17:26
Perhaps it was and Log4om as Adminitrator, but probably not, because now I have a warning window when it starts up and it wasn't there before. But I didn't have to run other applications /running in parallel/ in Admin mode, and now I have to because if I don't, they can't access data from Omni-rig.
Nothing has changed in my configuration, but after updating, Log4OM, if it is started first, later running applications could not connect to Om.i-Rig. I changed all the launch mode (to Admin) and now they work. Also, as a notice, if I don't run Log4OM, all applications work with Omni-Rig without the need to run in Admin mode.
I'm just signaling that I didn't have to do it before and everything worked fine. Perhaps my previous installation gave Admin permissions to Log4OM (worked very well) and therefore the other programs did not require Adm permissions.
From my point of view, the problem is solved, but I couldn't figure it out, so I asked a question and got an answer instantly - Thanks.
PS.
To sum up - I did not need to update version 2.18 because it worked very well, now, apart from the problems that I have fortunately solved thanks to your help, I see three red bars "QRZCOM" in the "Stats F1" window, which I do not know how to turn off (I only use LoTW confirmations)
73 Jacek SP9ODU
PS.
73 Jacek SP9ODU
