Locator squares
G0OFE
Re: Locator squares
Post by G0OFE »
Band and mode, I would say. For instance, FSK441 (digital) is used for meteor scatter for example. Just treat it as any other award - DXCC/IOTA etc.
If you're thinking of going down the route of a pre-prepared list of grids that exclude the large areas of "wet" or "frozen" ones, then I would be quite happy to put in the work of preparing such a list.
Re: Locator squares
I'm experimenting with image recognition...
In case I will fail I'll advise you there
Lele
PB4FUN
Re: Locator squares
Post by PB4FUN »
Why exclude wet squares ?
How about working me than as PB4FUN/MM ?
Re: Locator squares
Hi Meindert,
think some guys not knowing that there are a lot of /MM awards. For most of them you need a locator to define the position ...... Think it´s not a good idea to exclude wet and cold grid squares. ;) ;)
Some worldwide maritime mobile awards here as an overview: http://www.assoradiomarinai.it/award/maritimeawards.htm
G0OFE
Re: Locator squares
Post by G0OFE »
Wet squares and /MM did cross my mind, I must admit........
Re: Locator squares
Billions of squares... wow...
Re: Locator squares
:mrgreen: :mrgreen: Yes, that´s true .... I´m not shure that any other logger make this possible but when not "YOU ARE THE FIRST" :mrgreen: :mrgreen:
B.t.w.
If i work /MM i put in the locataor information that the /MM will provide. If i take a look with the search funktion i let me show all /MM which are confirmed by paper or LotW and eQSL (AG) if the award manager provide this. Think your search function is verry efficient if used correctly :mrgreen: ;)
