Posts: 11618 Joined: 21 Jan 2013, 14:55
Post
by G4POP » 18 Nov 2024, 22:16
hubertk wrote: 18 Nov 2024, 20:46
ok but when I choose radio in wsjtx everything is ok. The problem is when I choose omnirig.
Did you first set up omnirig in Log4om?
Once set up was log4om working OK with radio
Are all programs being run as an administrator?
sp5hub
Posts: 6 Joined: 16 Nov 2024, 13:38
Post
by sp5hub » 19 Nov 2024, 10:22
So I have checked again: all programs log4om, omnirig, wsjtx as administrator acording to Your guidlines.
Yaesu 891 goes to soundcard and in soundcard to mic and to speakers
Log4om - radio -> yaesu 891
wsjtx radio -> omnirig1
here i can hear the sound of miauo but wsjtx and grid tracker do not decode
When I turn off the log4om and set radio in wsjtx to Yaesu891 everything is ok
So the problem occurs when log4om is in yaesu 891 and wsjtx in omnirig mode. When wsjtx is in yaesu mode everything is ok.
Post
by G4POP » 19 Nov 2024, 10:39
hubertk wrote: 19 Nov 2024, 10:22
How does 891 go to soundcard - 891 mic and speaker audio to PC or USB Audio codec via a USB cable?
Is Log4OM using Omnirig or Hamlib?
Screen shot of your adio selection in WSJT pleas
sp5hub
Post
by sp5hub » 19 Nov 2024, 10:52
so there is a device that goes to computer via usb and there are two cables that go from the device to Yaesu and two cables that go from the device to the external sound card that is also pluged with usb to the computer.
On that printscreen I show You the option that is working that is why there is yaesu 891 in Radio.
and the second screen that is not working with omnirig as radio -> in this case I can hear the sound but neither grid tracker nor wsjtx decode it.
Log4om uses omnirig.
Thank You for Your help, I hope my case will help You develop your application
h
Zrzut ekranu 2024-11-19 120018.png (24.89 KiB) Viewed 1011 times
Zrzut ekranu 2024-11-19 115621.png (172.55 KiB) Viewed 1014 times
Zrzut ekranu 2024-11-19 114815.png (169.91 KiB) Viewed 1017 times
Post
by G4POP » 19 Nov 2024, 13:14
You must select omnirig rig 1 in wsjt, if wsjt, omnirig and log4om are all set to "run as an administrator" they will all function correctly together.
Can you post a screenshot of the wsjt config audio tab please
In your audio device drop down menu do you see anything like 'audio codecc'?
Post
by G4POP » 19 Nov 2024, 13:19
Just had a thought!
You did download the yaesu usb drivers and install them didn't you
If you just rely on windows drivers you will have issues
