LOTW settings in Confirmations wont save
G7CQW
Re: LOTW settings in Confirmations wont save
Post by G7CQW »
Just checked the Log and it does say No, I was assuming that the Confirmation screen would still show the parameters entered, am I mistaken with this.
G7CQW wrote: 18 Aug 2023, 15:16 Hi Terry, when I enter the information into the Confirmations screen and save as you have shown above then come out of that screen and go back into the same Confirmations screen nothing is listed. i.e. the LOTW and the "No" "No". I haven't checked the log screen.
If you click the drop down and select LOTW in the Program Config/confirmations menu it will show what you previously saved, well it does for me!
Log4OM does not know what type of confirmation you want to edit until you select one from the drop down
G7CQW
Post by G7CQW »
Thanks Terry, must be something wrong at this end, sends ok to LOTW but doesn't show the parameters entered and saved?
G7CQW wrote: 19 Aug 2023, 06:57 Thanks Terry, must be something wrong at this end, sends ok to LOTW but doesn't show the parameters entered and saved?
I would not worry about it clearly its a local glitch but if its saveing the QSO's with LOTW sent = NO and LOTW RX = NO then all is fine
G7CQW
Post by G7CQW »
Ok, thanks for your time and input Terry, much appreciated.
73 Tony.
