I've checked the source file from clublog, and it's reporting wrong informations.
These are the first 4 entities in ranking requested from clublog:
"1":"158","2":"294","3":"285","4":"293" in the form (rank:dxcc)
We already sent a mail to Clublog team to help them finding the issue.
The web list seems ok.
DXCC Most Wanted Rank
Re: DXCC Most Wanted Rank
Michael Wells of Clublog seems to have resolved this issue now.K0HB wrote:Further to the above, I experimented by leaving the application, then renaming "rankng.xml" to "xxranking.xml", then restarting the program.
Log4OM generated a new copy of "ranking.xml" but it contains the same unusual rankings as the previous copy.
Please go to the "Settings" menu in Log4OM and click "Clublog Database/load ClubLog Database" to update the ranking file.
Juergen,DF5WW wrote:Hi Daniele,
i checked this out with a test spot and see the same issue here in the latest Beta ..... USA is ranked at 11 instead of 340. See attached picture
In the cluster F3 tab you can generate a test spot using "Spot simulation" this test spot does not get sent tom the public DX cluster it just works within Log4OM for testing alters, filters, highlighting etc
Your instructions for repair did not work for meG4POP wrote:Michael Wells of Clublog seems to have resolved this issue now.K0HB wrote:Further to the above, I experimented by leaving the application, then renaming "rankng.xml" to "xxranking.xml", then restarting the program.
But here is what did work.
1) Exit Log4OM.
2) Search your computer for the file "ranking.xml". Mine is located at C:\Users\HANS\AppData\Roaming\LogOM\ranking.xml
3) Delete "ranking.xml" from your computer.
4) Launch Log4OM
5) Open the Cluster (F9) tab.
Log4OM will build a new (correct) "ranking.xml" and all is now well at the K0HB Superstation!
Hi Terry,G4POP wrote:Juergen,DF5WW wrote:Hi Daniele,
i know and that´s exact the way i tested this
Very strange it works fine for me and a couple of my tester friends as well as Daniele!K0HB wrote:Your instructions for repair did not work for meG4POP wrote:Michael Wells of Clublog seems to have resolved this issue now.K0HB wrote:Further to the above, I experimented by leaving the application, then renaming "rankng.xml" to "xxranking.xml", then restarting the program.
1) Exit Log4OM.
4) Launch Log4OM
This worries me because clearly the Clublog update is not working for you!
Please close log4OM and then restart it
Now follow the instructions that I provided
Then go to Help/Show log
Save the log and EMAIL IT TO ME - DO NOT POST IT ON THIS FORUM
I can confirm that doing the clublog update as per your instructions did it for me just fine.
Aldo VA3AG
Thanks Aldo
Keep well and be happy
Hans,
As I have not received a reply to my email do I assume that your Ranking issue is now resolved?
1) Exit Log4OM.
4) Launch Log4OM
Thank you for emailing me your Log4om log and I responded by email on Tuesday.Very strange it works fine for me and a couple of my tester friends as well as Daniele!
I haven't seen your email response to my log.
