LOTW upload Freezes
DL4DBM
Re: LOTW upload Freezes
Post by DL4DBM »
I'm not quite sure if this could help.... I had this same problem but it started with me as soon as I'd changed some ALREADY uploaded QSO's to LOTW from "YES" to "NO". I made some nice contacts in the past to whom I already sent a confirmation through LOTW but never got a confirmation back... So I changed these contacts from "YES" to "NO" hoping by sending my confirmation again, these stations would reply but here the problem with freezing started. As soon as I changed these QSO back to "YES" again, the problem disappeared. Somehow it's not possible to send the confirmation through LOTW again.
Have a great weekend!
Ben (DL4DBM)
WR0H
Post by WR0H »
If you upload an ADIF directly via TQSL, it allows you to override the "one upload per qso" limitation.
Now I find myself in the strange situation of my log showing that I have received LOTW confirmations without sending one--obviously not the case. QSO Manager does not allow bulk editing of LOTW fields, so I'm stumped as to how to update the qsos, other than one at a time.
WR0H wrote: 03 Feb 2024, 17:24 If you upload an ADIF directly via TQSL, it allows you to override the "one upload per qso" limitation.
Shawn,
If you utilize "QSL Manager" you can adjust the Sent & Received values.
Adjustments can be made one QSO at or a time or in a 'bulk' mode.
"QSL Manager" is NOT the "QSO Manager".
Give it a look, check out the User Guide and/or also watch the videos that Terry has created.
IW3GCR
Post by IW3GCR »
Hi everyone, I too have the same problem.
QSOs are not automatically uploaded to Lotw, but I have to use the method with the TQSL program or manually, one QSO at a time.
Windows10 system and Log4Om version 2.31
Thank you
Nicola IW3GCR
Nicola IW3GCR
IW3GCR wrote: 28 Feb 2024, 12:13 Hi everyone, I too have the same problem.
Thank you
Nicola IW3GCR
What TQSL version number are you using?
IW3GCR
Post by IW3GCR »
Hi Terry
Tqsl v. 2.72
Nicola IW3GCR
Nicola IW3GCR
OA9DVK
Post by OA9DVK »
It seems it is not just me then...
INFO: ADIF File created successfully.
INFO: TQSL Version 2.7.2
No private TQSL Password set
Executing TQSL with upload
MANAGED MODE SET
No matter what I do, there is no chance to have my qso uploaded.
Any clues?
73 91 de Daniel
OA9DVK (also IK2SGL)
From somewhere in the Amazon Rainforest
Permanent activity from the Communal Reserve of Chayu Nain, ref. OAFF-0040
Latitude - 5.023231 ( 5 1' 23'' S)
Longitude -78.340072 (78 20' 24'' W)
IW3GCR
Post by IW3GCR »
I can't find one: manually the upload works, automatically it doesn't.
Nicola IW3GCR
Nicola IW3GCR
Manually from Log4om?
IW3GCR
Post by IW3GCR »
IW3GCR wrote: 28 Feb 2024, 15:19 I can't find one: manually the upload works, automatically it doesn't.
Nicola IW3GCR
Manually is working fine !
Nicola IW3GCR
Nicola IW3GCR
