IC-7300 + JTDX
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
Well, I just tried low on both RTS and DTR on omnirig... looks like it is working correctly now...
So next, I'll try to use JTDX also...
Thanks + 73
Paul F6EXV
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
Now, whether I use Omnirig or Icom 7300 on JTDX, frequency is not copied, and JTDX shuts off...
Which should I use ?
Thanks + 73
Paul F6EXV
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
I think I got it working !
I uninstalled everything, reinstalled, restarted the whole process.
Ther thing that was unclear was the fact that in L4OM, the rig must be Icom7300, and in JTDX, it must be Omnirig...
Now, it works !
Thanks + 73
Paul F6EXV
Re: IC-7300 + JTDX
My first reply in this thread suggested that, guess you did not check!
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
Hi
Upon switching on computer this morning, it no longer worked....
I launch Log4OM, and then JTDX. JTDX opens up the omnirig window, and after a few seconds (the rig is selected, speed and everything is correct), it will close JTDX...
Can you point me to the video you were refering to ? I searched youtube for Log4OM + JTDX, only got an EA8 video...
Thanks + 73
Paul F6EXV
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
Terry
Can you please point me to the video you have mentioned, I cannot find it.
Thanks + 73
Paul F6EXV
Re: IC-7300 + JTDX
Did you install the Icom USB drivers or just use the Windows drivers for the Icom USB connection?
I also produced this PDF instruction sheet
IC7300 CAT control.pdf
(118.52 KiB) Downloaded 56 times
Take your pick of videos https://www.bing.com/search?q=setup+CAT ... cc=0&ghpl=
F6EXV
Re: IC-7300 + JTDX
Post by F6EXV »
Hi Terry
The Icom USB driver...
Thank you for the document. I will see it thoroughly !
Thanks + 73
Paul F6EXV
