in fact I was very generic. I'm sorry.
RADIO: IC-756 PRO III
VSP: ETERLOGIC SPLITTER
SOFTWARE: LOG4OM LAST VERSION & FLRIG
OS. WINDOWS 8.1
INTERFACE CABLE: MICROKEYER USB II
73 de iz8gcb Gaetano
Size of frequency read out
Re: Size of frequency read out
Hi Gaetano,iz8gcb wrote: RADIO: IC-756 PRO III
OS. WINDOWS 8.1
I have it working 100% OK on Win 7 64 bit, 32 bit and Win XP - I don't and will not use Windows 8
There might be some small differences, so I suggest checking the following:
1. Make certain that you are using FLRig version 1.3.15 or later
2. Try a different interface, it could be that the Microkeyer does not like Virtual Serial Ports?
3. Disable Windows "User Account control" (UAC) it can cause all sorts of issues
4. Temporally disable any firewalls and virus/malware protection to check if they are blocking something
Attached is a diagram of my set up and also a screen shot of it all working in synchronisation
- Slide1.jpg (89.74 KiB) Viewed 12261 times
- G4POP.jpg (858.17 KiB) Viewed 12261 times
Is it just me or does anybody else see Terry's attachments as corrupted?
Guy
Guy
Same here, attachments (screen shots) are corrupted.
Claus
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
This happened to most attachments at the time we changed to a new server
Unfortunately I don't have all of the items that were posted
Just wanted to check it was not something at this end. I have never even managed to see any of the images that you used to post in TIFF format via a link.
