Automatic upload on new QSO not working?
Re: Automatic upload on new QSO not working?
WR3Y wrote:Auto uploads work great, but I can't upload to LOTW. I have to do it manually with the TQSL program separately. When I try to use LOG4OM I get an error message that the file is not in this path, but I am using the default path.
Says operation completed with errors:
TQSL file not found on this path
c:\ProgramFiles\trustedQSL\tqsl.exe. Exiting
I never used the private sign pass. Works fine when I upload manually with TQSL.
Do I need to put the certificate somewhere for LOG4OM to see it?
Rob
Rob
First find where you have installed the TQSL.exe on your computer
Having found where it is located make certain that in the Log4om settings/external logs tab the path to the TQSL.exe is the same
WR3Y
Post by WR3Y »
Yes thanks again Terry and Juergen that was the problem. The path I needed to enter was the same, however I needed to add (x86) after Program Files.
All wonderful now and so much more convenient!Great software I will recommend it to everyone. :D
Rob
