Trevor,
What specification is your computer, OS, processor and ram?
Cant get my head around this because it should work for you as it does for me!
Integration with HDSDR
Re: Integration with HDSDR
Intel Quad core @3.00Ghz
3gb Ram
Win 7 32bit
It's getting a bit old now but still does the trick for me,
What other programs use omnirig so I can test and see if HDSDR is the problem,
Trevor
3gb Ram
Win 7 32bit
Trevor
Trevor,
No the computer is fine I have tested this on a Pentium 4 machine and it's OK.
I am inclined to suspect something like malware, a virus or some software you have on the computer causing the issue.
You are running Log4om and everything else including the database on the same local computer aren't you? Your not running it across a network?
Othe progrms that use Omnirig are MiXW, CW skimmer and anything else in this list
http://www.dxatlas.com/omnirig/CompatibleSoft.txt
Hi Terry
Yes it's all local to the one machine, I doubt I have a virus I'm very careful with emails or downloading files, and AVG is not giving me any warnings,
I'll try CW Skimmer as I have that and see how it works,
Trevor
Trevor
SO I tried CW skimmer and Log4OM and no joy only the first to be opened would work,
I tried JT65 HF and CW skimmer and I couldn't get JT65 to work at all,
I downloaded DX monitor and again if it was running either CW Skimmer or Log4OM would connect,
Looks like I have a issue with Omnirig Its a clean install that I did yesterday
EI2GLB wrote:SO I tried CW skimmer and Log4OM and no joy only the first to be opened would work,
I will have to try some of the other Omnirig programs and see,
Have you tried a new download and install of Omnirig?
Also I have heard of someone using HRD that had to remove AVG because even with it disabled it was blocking the Comms
Yes Terry I uninstalled Omnirig an installed a newly downloaded version but no change,
It's a strange one
It's a strange one
It's a 756 Pro 2
Same as me I have the Pro III
Let's talk off the forum to save all this typing
Do you have Skype? If so email me and I will give you my Skype user name
THIS IS STARTING TO BUG ME
