Cluster send command not working
K2DJL
Re: Cluster send command not working
Post by K2DJL »
Doug:
Thank you! You were a tremendous help and extremely knowledgeable! I urge all to donate to Log40M!
Doug: as we discussed, the only other issue is having to double click 2x onto a cluster station in order to obtain the correct frequency. The first double click is usually several khz away. The second double click will get you to the correct frequency. Doug, you and I discussed that this seems to be characteristic of Yaesu rigs. Hopefully this bug can be worked out.
Thank you Doug and to the Log40M team!
Dan 73 K2DJL
