QSL upload issue
Re: QSL upload issue
Old post and seems like this has been partially fixed but not for ClubLog. Just wanted to make sure I am not missing something on my end.
After importing a contest via ADIF from N1MM I cant upload to clublog.
2020-03-22 18:21:36.8690 INFO: [#=zxtf1M3_cENvUFrqzWi0j6fZiIdTH] : [CLUBLOG UPLOAD LOG] Uploading clublog file containing 395 QSO's
2020-03-22 18:21:40.4288 ERROR: [#=zU7pP2ZTM_kyDRqX9Sg==][MoveNext] : [EXCEPTION] The remote server returned an error: (403) Forbidden. System.Net.WebException: The remote server returned an error: (403) Forbidden.
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at L4ONG.Framework.FWWeb.#=zU7pP2ZTM_kyDRqX9Sg==.MoveNext()
2020-03-22 18:21:40.4328 INFO: [#=zxtf1M3_cENvUFrqzWi0j6fZiIdTH] : [CLUBLOG UPLOAD LOG] Upload exception. Check log
2020-03-22 18:21:42.9658 INFO: * [#=zxtf1M3_cENvUFrqzWi0j6fZiIdTH][6142 ms] : [CLUBLOG UPLOAD LOG] ###### END ######
Rich,
Your errors might be due to a re-allocating of the Clublog servers for the COVID-19 situation.
See attached email sent out by Michael - G7VJR with Clublog.
clublog.txt
(2.43 KiB) Downloaded 193 times
OK but it first appeared weeks ago (before COVID-19 was an issue), so was not sure if it had been addressed or not.
N1IDN
Post by N1IDN »
Had the same issue, getting an upload exception for Clublog ONLY.
The solution (for me anyway):
Settings>External Services>Clublog -- Make sure the "callsign opt *" is filled in.
That's all it took for the upload to work properly.
