problem Voice record on air
Re: problem Voice record on air
You have selected the wrong audio devices in the to and from radio, if your using a usb cable they should be called 'audio codecs'
f4gwm
Post by f4gwm »
hello terry
no this is not the problem because when we select the data mode in ftdx 3000 all is ok not changing anything in the log4om
so i can tell that the audioo configuration is ok
and when you go on the usb or lsb it doesn t work no audi out put
when i use other voice keyer software i put the same configuration and it is working so i thinkit is problemn from log4om not a configuration problem
F4GWM
CEDRIC
f4gwm
Post by f4gwm »
hello,
i have always the same problem. I have found why the voice keyer dont go on air.
In the menu 103 in the ft dx 3000 you can choose the source of the input sound.
default is front in fact microphone you can choose usb or data.
if you choose usb the sound from the usb codec is ok and the voice keyer go well and you can ear the sound on the air.
but almost the time you must change between front and usb it is not normal because it is not easy for the traffic.
thatis why i think the problem is on log4om beacause when you try another software like mmsstv for example when you want to to transmit using usb codec it is not necessary to change between usb and front in the menu 103.
automaticly the sound go on the air whithout changing anything in the menu.
the option for the sound are the same same configuration for all the softaware evryone is ok but not for log4om you lust change the input sound in menu 103 .
that is the problem the voice keyer can not be used in this configuartion beacause it is not an esay way for qso.
is it possible to do something about that on the soft ?
73 cedric
F4GWM
CEDRIC
