log
mm3awa
Re: log
Post by mm3awa »
Not installed, thinking of just finding another logging programme, never touched any setting and this happens,
Re: log
Your prerogative of course but by your own admission it was working fine and I have tested here on two computers and as you can see from my screen shot earlier it does a clean lookup!
Ergo something has changed your end, either by mistake or by external forces like a windows update, freshly installed software or perhaps a virus.
TeamViewer is a free download and requires zero knowledge on your part, alternatively send us a support request and we will check if we can see the issue without having to access your pc - see our user guide for instructions for sending a support request.
However if you feel enough is enough why not try HRD, WINLOG, DXLABS SUITE OR SWISSLOG all of which will accept the ADIF file you will need to export from Log4om.
Your choice
mm3awa
Re: log
Post by mm3awa »
Thanks i have have installed team viewer, i would be very grateful if you can have a look i have reinstalled log40m and uploaded log etc, still same , no grid or operator name.
Re: log
mm3awa wrote: 26 Mar 2021, 19:05 Thanks i have have installed team viewer, i would be very grateful if you can have a look i have reinstalled log40m and uploaded log etc, still same , no grid or operator name.
When are you available?
mm3awa
Re: log
Post by mm3awa »
now till 20:15 local time
Re: log
Open TeamViewer and leave it open
Email me your user I'd and password to g4pop (at) arrl.net
Password is case sensitive so be vigilant
mm3awa
Re: log
Post by mm3awa »
now til 20:15 local time,, sent to your email,, thank you.
mm3awa
Re: log
Post by mm3awa »
Thanks to admin for help, due to my stupid error, really appreciate the time and help. 73 DE MM3AWA Gordy.
Re: log
All on-line lookups were disabled in the config/info providers
F5RUE
Re: log
Post by F5RUE »
I got same issue. No Gris is coming.
My config : L4OM, GridTracker, JTDX
Connections : ADIF 2236, JT 2238 (UDP forward from GridTracker)
I don't understand ..... :o :o
Tks Rick F5RUE
