Losing CAT FT101MP
Re: Losing CAT FT101MP
Can't see your previous message
Drat! serves me right for using the tablet.
All I said was that as other radios work OK presumably with the same PC it indicates that the issue is either
Radio problem - Try a full factory reset
Cable issue if its a different cable than that used by the other rigs
Omnirig rig ini problem - Although I doubt that as the problem would be reported by more users of the 101
I will give it a try probably not today.
I dabble in contests where I use N1MM and that seems to work OK, something querky somewhere.
As you say if it were omnirig other users would be having issues.
Bill
Bill
Much as I dislike Hamlib you could try that and see if you have the same issue?M0TDW wrote: 08 Apr 2025, 09:30 I will give it a try probably not today.
Bill
