Page 4 of 5
Re: LoTW weirdness
Posted: 28 Jan 2018, 14:58
by WT0DX
In the 1.31.00 release.... is this the fix for the LOTW download issue: "Added checks to WAS import in order to try fixing non coherent data for USA, Alaska and Hawaii." ?
Bill WT0DX (formerly WB9KPT)
Re: LoTW weirdness
Posted: 28 Jan 2018, 16:29
Yes
Re: LoTW weirdness
Posted: 28 Jan 2018, 18:23
by EC1DQ
Hi all,
I updated to the last release and I still have something with a "DC" station. It appears like state number 51, as "DC // District of Columbia" on the state field and "DISTRICT OF COLUMBIA" on the County field. It appears with the same red box (NOT FOUND) as it did on last version with the other states. Any comment about it?
Thanks!
Re: LoTW weirdness
Posted: 28 Jan 2018, 18:30
by w0ls
It appears that this version (1.31) fixed all of my state entries. Thanks!!
Harry
W0LS
Re: LoTW weirdness
Posted: 28 Jan 2018, 18:40
by DF5WW
EC1DQ wrote: 28 Jan 2018, 18:23
Hi all,
Thanks!
That is not a Log4OM or LotW Problem. It´s a problem of the Callsign Owner which write "DC" as a State in qrz.com or other
online services. The same appears for the DXCC U.S. Virgin Islands when those Users write "VI" in the state field.
DC is not a state of the United States and VI also is not one, but those wrong inputs at qrz & co. will force this problem.
An example:
If i go to qrz or hamqth and fill "RP" (for Rhineland Palatinate" in the state field you will have an unknown state more in the
WAS statistics. It´s outside of the United States (as VI for Virgin Islands is too) but it will be shown as "Unknown" in the WAS
Stats ...
Re: LoTW weirdness
Posted: 28 Jan 2018, 20:38
Log4OM fixes only states in usa, Alaska and Hawaii that have a valid state in the was.csv reference file. Everything else it's managed as unrecognized and Log4OM doesn't touch data it doesn't perfectly know
Re: LoTW weirdness
Posted: 30 Jan 2018, 12:42
by KD0ZV
So, I am assuming DC (which is a weird one) just needs the state removed and save it?
Re: LoTW weirdness
Posted: 30 Jan 2018, 17:42
yes, or replaced with the correct state.
Re: LoTW weirdness
Posted: 02 Feb 2018, 23:11
by WA2SQQ
So I had many entries that had this problem. I corrected many, manually. I just updated to 1.31.1 Will this fix all the remaining ones automatically, or only new entries looking forward?
Re: LoTW weirdness
Posted: 03 Feb 2018, 07:37
WA2SQQ wrote: 02 Feb 2018, 23:11
Which issue are you refering to the change of syntax by LOTW or the recording of incorrect stat information like DC?
