You must have Log4OM running while logging in JTDX the UPD connection is real time and therefore if running JTDX stand alone the QSO's will not be logged.
No, other than manual manipulation of the QSO's there is no work around that you can do
ADIF Functions - Monitor
Re: ADIF Functions - Monitor
That was my understanding of UDP, I just wanted it confirming. Thanks.
OK I have spoken to Lele at length about this and apparently its by design!G6FZU wrote: 03 Dec 2023, 23:20is there a fudge I can apply, e.g. manually set something in a configuration file?
When you save and apply the Adif monitor the 'upload' flag is saved in that config so that each time that specific ADIF monitor is used the upload is actioned.
Here is an extract from the config file showing that upload is enabled
AdifMonitorEnabled": true,
"AdifMonitorList": [
"AdifMonitorId": "d301ebc5-89fb-4308-b4c2-5d88d2948fe1",
"FileName": "C:\\Users\\g4pop\\fldigi.files\\logs\\logbook.adi",
"AfterDownloadURL": "",
"DeleteAfterLoad": false,
"ImportMatchingCallsign": true,
"LastCharacterRead": 780,
"LastUpdated": "2023-09-13T18:38:26.8493704Z",
"Enabled": true,
"AutoUpload": true,
"UpdateExternalSources": true,
"IsWebUrl": false
The reason is that you might have more than one ADIF monitor setup, perhaps for WSJT, FLDigi, MRP40 etc so for each set up you can have a different upload requirement, therefore the check box defaults to un-checked.
