LOTW upload Freezes
IW3GCR
Re: LOTW upload Freezes
Post by IW3GCR »
Hi Terry, debugged again, there is a QSO to send, DK6MR, with the necessary modifications, disk E is from the computer, while disk D is a flash memory, also from the computer. Corrected point 3 and point 4.
But now it works, I really think my mistake was in point 3.
Terry A big THANK YOU for YOUR GENEROUS PATIENCE.
Nicola IW3GCR
I sent you the zip file anyway, it should be
right now.
Nicola IW3GCR
Nicola IW3GCR
IW3GCR
Post by IW3GCR »
We'll see in the next few days, I'll keep you informed. The DK6MR QSO has been loaded, luck, a coincidence...?
Nicola IW3GCR
Nicola IW3GCR
Nicola,
Clearly the confirmation status was the main issue but I suggest the following also:
I strongly suggest that you change the LOTW temporary drive to C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\temp this will improve the LOTW upload on closing Log4OM
I also suggest that you install either google drive or Dropbox (Not Microsoft OneDrive) and store the main SQLite database there, this will ensure that you cannot lose it and also make it accessible from any computer you own.
Once you have done the above tasks you can then tidy up your UDP connections
IW3GCR
Post by IW3GCR »
Hi Terry, I changed the Lotw temporary directory, and checked the udp connections.
Nicola IW3GCR
Did you relocate the logbook database sqlite file?
N4RF
Post by N4RF »
I can upload from TQSL OK. I can download via LoTW V2 no problem. If I use Utilities - QSL manager - upload selected QSO(s) - click on upload arrow into cloud Then the message is:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.7.2
No private TQSL password set
Executing TQSL with upload
MANAGED MODE SET[/b]
THEN NOTHING. I can leave it overnight and the same message will be there in the morning. But, manual uploading an .adi file to TQSL works FB.
Any suggestion?
N4RF wrote: 20 Mar 2024, 23:49 I can upload from TQSL OK. I can download via LoTW V2 no problem. If I use Utilities - QSL manager - upload selected QSO(s) - click on upload arrow into cloud Then the message is:
Any suggestion?
And your Log4OM version number is?
N4RF
Post by N4RF »
Version 2.32.1.0
Thanks Terry
KI0ER
Post by KI0ER »
I am experiencing the same issue even after trying all the suggestions Terry made. I finally did get it to work, however. I had 18 total QSO's to upload (by searching by upload value of NO).
Instead of selecting all, I selected 5 or so at a time, and selected Upload ... then I got the usual messages from the upload processing and the qso's were uploaded successfully.
I thought perhaps I'd find one QSO with an issue, but I didn't. I ran the upload process 4 separate times in small batches of about 5 or so to get all 18 of my ready-to-upload QSO's.
I don't know what the upper limit is for uploading LotW QSO's, not sure there should be one. I suspect some kind of a software timing issue somewhere.
73!
Roy - KI0ER
N4RF wrote: 21 Mar 2024, 13:31 Version 2.32.1.0
Thanks Terry
email me a support request to my QRZ email address
BUT FIRST
In Program Config\Program settings set log level to 'TRACE'
Now re-enact the problem on close down/upload
Re set Log level to Info and restart Log4OM again
