Page 5 of 5
Re: probleme zone ITU et CQ
Posted: 17 Feb 2022, 19:02
by F1TRF
bonjour
version 2.20.0 installée = problème toujours présent
retour encore une fois vers la 2.8.0
Posted: 18 Feb 2022, 19:55
by KI5IO
F1TRF wrote: 17 Feb 2022, 19:02
bonjour
Laurent,
Noted and yet again have brought back to the Mantis list for "hopefully" fixing. Been far too long since you first reported.
Tnx for your patience.
Posted: 09 Aug 2022, 11:44
by F1TRF
bonjour a tous
version 2.23.00 installée
problème toujours présent, je dirai même que cela a empiré:
inversion des zones CQ et ITU sur certain qso
plus de 2 minutes pour charger le fichier SQLite
Posted: 26 Oct 2022, 15:29
by KI5IO
F1TRF wrote: 09 Aug 2022, 11:44
bonjour a tous
Laurent,
Pls provide an update with your ITU/CQ issues. We've continued to do testing and are just not able to replicate what items you have noted.
If you would be very clear as to when/how you are seeing the ITU/CQ issues. IE: Is Log4OM V2 running by itself with a simple CAT connection to your rig? Or are you experiencing the issue when you have WSJTx / JTDX and/or JTAlert / Gridtracker also in operation?
Be very clear about which APP(s) you have running and how configured on the connection to Log4OM.
Are you using UDP connections for the external APPs or are you instead or also importing an ADIF file from WSJTx, etc?
It also appears that you have also recently been using Log4OM V 2.23.0.0
What is your Info Provider connections as well as your Info Provider Configuration as it relates to QRZ, HamQTH, Clublog, CTY, etc.? The priority of the arrangement of the Info Providers can have an impact on CQ/ITU zones as well.
As I've noted ... we keep trying to replicate and have been unable to do so and Lele has made many changes to help address items you have noted since you first mentioned this on 18 Sep 2020.
Posted: 07 Jan 2023, 20:22
by F1TRF
merci pour le temps passé, mais j'ai abandonné.
