Log Management
Posted: 19 Aug 2014, 17:37
Before I start, I've only started with Log4OM today.
I haven't found out how to do it so I presume there isn't a way of doing it so I will ask away, If there is please someone share how with me.
I stupidly imported my ADIF twice, so now I have two entries for every QSO, to manually sort them is going to take forever, so how can I bulk highlight and edit. Would a highlight QSO's and delete be an option.
Also in Layouts how do I get the QSO number from the database, I can't see an option for this. I am using mySQL so it should be possible as I presume the Primary key will be a QSO number (or int +1) for each record created.
Also what about Sync from HRDLog or other online log (QRZCQ)
Other than these few things, I will be using Log4OM for day to day logging, I am even going to try using it for contesting... (alongside N1MM in case of issues)
