WWFF Cluster support
VK2MET
Post by VK2MET »
The WWFF org has launched a new spotting cluster at spots.wwff.co
The spots are good and they have also mounted a DXCluster server at spots.wwff.co on port 7300
I can connect to this server and see console output - see below..
But the spots are not parsed and do not get listed in the spots list.
So I'm looking for someone who might know what is missing from the output or what is causing a conflict exception on the decoding of the spot line
Alan
example output - setting the message about read only made the Flex Cluster utility read the spots, but Log4OM still does not read them
17Jun2025@01:18:41 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:19:58 WWFF-SRV -> ALL This server is read-only and does not accept commands.
DX de VE6JY: 14063.3 N7JTT KFF-3528 CW Re-spotted via RBN 0120Z
17Jun2025@01:21:34 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:22:43 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:23:27 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:23:59 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:24:39 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:25:04 WWFF-SRV -> ALL WWFF server telnet spots.wwff.co 7300 | Web: https://spots.wwff.co | Read-only WWFF spots
17Jun2025@01:25:35 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:26:23 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:27:21 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:27:56 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:29:09 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:29:56 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:30:26 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:31:22 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:32:26 WWFF-SRV -> ALL This server is read-only and does not accept commands.
DX de N7JTT: 18075.0 N7JTT KFF-3528 CW QSY 0132Z
17Jun2025@01:33:29 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:34:27 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:35:04 WWFF-SRV -> ALL WWFF server telnet spots.wwff.co 7300 | Web: https://spots.wwff.co | Read-only WWFF spots
17Jun2025@01:36:05 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:36:50 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:37:41 WWFF-SRV -> ALL This server is read-only and does not accept commands.
DX de N7JTT: 21060.0 N7JTT KFF-3528 CW QSY 0138Z
17Jun2025@01:39:29 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:40:12 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:41:03 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:41:57 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:43:20 WWFF-SRV -> ALL This server is read-only and does not accept commands.
DX de N7JTT: 10114.5 N7JTT KFF-3528 CW QSY 0143Z
17Jun2025@01:44:42 WWFF-SRV -> ALL This server is read-only and does not accept commands.
17Jun2025@01:45:04 WWFF-SRV -> ALL WWFF server telnet spots.wwff.co 7300 | Web: https://spots.wwff.co | Read-only WWFF spots
17Jun2025@01:45:51 WWFF-SRV -> ALL This server is read-only and does not accept commands.
Re: WWFF Cluster support
Functions perfectly for me!
0658 spots.wwff.co:7300 (ssid:): login: 17Jun2025@06:58:27 WWFF-SRV -> ALL Welcome to official World Wide Flora & Fauna dx server. This is a read-only server.
0658 spots.wwff.co:7300 (ssid:): 17Jun2025@06:58:27 WWFF-SRV -> ALL WWFF server telnet spots.wwff.co 7300 | Web: https://spots.wwff.co | Read-only WWFF spots
0705 spots.wwff.co:7300 (ssid:): 17Jun2025@07:05:04 WWFF-SRV -> ALL WWFF server telnet spots.wwff.co 7300 | Web: https://spots.wwff.co | Read-only WWFF spots
0705 spots.wwff.co:7300 (ssid:): DX de OH1MM: 14333.0 OH1MM/P OHFF-1271 SSB 0705Z
0705 spots.wwff.co:7300 (ssid:): DX de R1LB: 14044.0 Z35M Z3FF-0077 CW Re-spotted via RB 0705Z
Screenshot 2025-06-17 080733.png (15.71 KiB) Viewed 411 times
Screenshot 2025-06-17 080945.png (21.94 KiB) Viewed 411 times
VK2MET
Post by VK2MET »
OK my defaults weren't as you have them with the commented SH/DX command
But it seems to be very strange refresh rate now that they appear. If I compare the website of the same spots, there are quite a few missing.
Anyway - it's not something I will rely on,
Thanks anyway..
https://spots.wwff.co/spots
Alan
VK2MET wrote: 17 Jun 2025, 10:10 OK my defaults weren't as you have them with the commented SH/DX command
Thanks anyway..
Alan
Did you consider the sever data udate frequency is probably slower than the Web display, we can only display what is sent as its sent - Look at the raw data in Telnet
