I have a question about the chat function in Log4omv2 (2.36. 1.0)
Today (17/06/2025) I wanted to do a chat with 2 stations. They let me know that they did not receive anything.
The same happened when they sent me a chat.
I did not receive a chat from them.
Station 1 work with L4
Station 2 work with GT
I worked both L4 and GT but nothing worked.
I know that Log4om uses the chat function of Gridtracker, but I was wondering if the settings in the config.ini file were correct.
In the past (a long time ago) this has already been changed. (I thought)
Now you can find that file (at least in my case) under (C:) users/name/AppData/Roaming/Log4OM2/Config.ini
That file contains the following:
[CHAT]
SERVERADDRESS = ws://oams.space
START_PORT = 18360
RANGE = 10
DEBUG_PORT = 18280
The question, is this correct?
I couldn't find a file with this in GridTracker2.
Chat function v2.36.1.0
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Member UBA-IPA
WCA: ON-01354
