Cluster connection.
G7BZD
Cluster connection.
Post by G7BZD »
I seem to be unable to connect to the cluster ?
It was alright last night when i last used the prog. Nothing has changed, pc is connected to the net.
My standby machine is doing the same as well ?
Comm services is green, and i can get Super Cluster up and running... but no cluster ?
When i click on connect it takes a while before it fails to connect, message in window says NOT CONNECTED.
Phil G7BZD
Re: Cluster connection.
Hi Phil
Have you tried another cluster?
It can only be that either you don't have an Internet connection or the cluster that you are trying to connect to is out of service.
G7BZD
Post by G7BZD »
Hi Terry.
I was using : 146.48.126.28:8000 but that seems unavailable, now using dxfun.com.8000
I notice som need a logon, i used dxcluster.ham-radio.ch on hrd, i take it i could just type it in, although as long
as i have a working "european" cluster it does not bother me, usually guides me as to where to avoid.
All working now, what would we have done before the internet ??
Many thanks.
Phil
I really don't know Phil :-)
Try the GB7MBC cluster at Morecome Bay
