Creating new award
Moderator: OE6CLD
F4IEX
Creating new award
Post by F4IEX »
Hi all,
Have recently tried to use the award management section of the program. Have read carefully the instruction manual as well as watched some vids on YT. Anyway, I still don't understand well (in the Award Type section), the difference between REFERENCE, QSOFIELD and CALLSIGN.
So far, my "test" awards seem ok and work correctly but I may make some mistakes.
Thanks in advance.
73 de F4IEX Eric
Re: Creating new award
Your just selecting what area the award should look at to find the match to the references that you imported into the award.
If you have imported a list of French latrines like FFSH-1234 then select Reference
If you imported a list of data included in the normal ASDF fields like grid references then select QSO fields
Etc
