Hi all,
I'm pretty new in software logging and after looking at the well known around, I've choosed Log4OM because it looks easy to use and complete.
So I've started using it from a few days and for normal QSOs it really goes like I would!
Yesterday I've tried using it in a 50 MHz local Contest and I was in trouble...
It was problematic to:
- enter first the callsign in the Info QSO tab
- then the program goes automatically in Contest mode tab to insert the Received report
- Switch with F1 to QSO Info tab and press 4-5 time tab to go to the Locator field, or need to take the mouse and click on Locator tab to insert it.
It's very confusing and sometimes I made error in typing in the wrong place!!!
Am I doing something wrong using Log4OM in Contest mode?
Has someone suggestions on how it must be used?
Thanks a lot for the help here
73 de maurizio IK1PFW
Contest mode suggestion
Re: Contest mode suggestion
Ciao Maurizio,IK1PFW wrote:Hi all,
I think that what you need is a locator entry field in the contest tab when contest mode is enabled? same as were do with RST sent and received.
Ciao Terry,
and thanks a lot for the very fast reply!
Yes, it would be very easy this way!
So I suppose no other way to deal with the Contest Mode.
I hope that Daniele and/or other people working around could put this new implementation in next release...This way one could use Log4OM also for contesting!!!
Thanks and 73
ciao
maurizio IK1PFW
Thanks and 73
ciao
maurizio IK1PFW
Added to our Mantis listIK1PFW wrote:Ciao Terry,
Thanks and 73
ciao
maurizio IK1PFW
Great Terry!!!
TU and 73
maurizio IK1PFW
TU and 73
maurizio IK1PFW
