MySQL - Table / Field Name Case Sensitivity
Posted: 29 Mar 2013, 00:33
Log4OM Team,
First let me thank you for providing the amateur radio community with such an awesome application! I have been looking for logging software that is able to utilize a MySQL database for quite a while. I primarily run a Windows machine for a home grown Excel log I built five years ago but also have several Linux machines. I would like to ask a favor for future versions of the application - could you code the application so that the table and field names match the same case as the database? I was successful with Log4OM creating the database on a MySQL Linux machine however the application will not run properly. MySQL on Windows is not case sensitive while Linux is. I have tried numerous times on the Linux machine to change the MySQL configuration to ignore case sensitivity but have not had any luck. I have screen captures available here. While I realize I am probably in the minority of running the Log4OM application with the database on a Linux machine I hope you take this request into consideration for future releases.
Thank you for your effort and hard work you have put into Log4OM.
-Brian, KB3ORR
-Brian, KB3ORR
