DLD - Deutschland-Diplom (DOK)
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the DLD - Deutschland-Diplom. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_DLD.xml) into the <user>/AppData/Roaming/LogOM/awards folder (or in the confog/awards folder if you're using the portable version) and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.darc.de/referate/dx/diplome/dld/en/
Claus, EI7JZ/OE6CLD
award_DLD.xml
(2.49 MiB) Downloaded 663 times
DLD 100.jpg (26.89 KiB) Viewed 6159 times
DLD 300.jpg (3.41 KiB) Viewed 6159 times
DLD 1000.jpg (5.69 KiB) Viewed 6159 times
Claus, OE6CLD/DJ0DX/EI7JZ
Re: DLD - Deutschland-Diplom (DOK)
Thank you Claus, you're doing a FANTASTIC work! :)
gi4fue
Post by gi4fue »
Hi Claus
Thanks for setting up the DLD Award - I presume the Sonder DOK's are from this year only
Regards
Charlie
OE6CLD
Post by OE6CLD »
Hello Charlie,
No, I used the most recent Sonder-DOK list published on the DARC website (2014/08). This contains all official Sonder-DOKs from 1971 up to 2015. Please take care, some Sonder-DOKs have been assigned to more than one callsign (which is in the group field). This means that there can be more than one entry with the same Sonder-DOK.
Claus, EI7JZ/OE6CLD
