QSL Information box layout
Posted: 11 Sep 2014, 03:33
by VK7XX
When you double click on a contact in the QSO Informatiuon (F7) or Recent QSO (F9) windows the Update QSO box opens. When you select the QSL Information tab, the layout of the boxes at the top is.........
QSL/ Sent - Sent Date - Received - Received date - QSL Sent via - QSL Received via
Now I am not saying that this is a problem, or in any way bad, but does anyone else thing it might look & feel better if all the "sents" and all the Receives" were adjacent to each other ???? as in .............
QSL/ Sent - Sent Date - QSL Sent via - Received - Received date - - QSL Received via
or, am I just too much of a virgo when it comes to layouts ???
John
Re: QSL Information box layout
Posted: 11 Sep 2014, 15:05
user interface is keep as clear as i can... but sometime i'm forced to add new fields and, again, sometime i can fail to reorganize following new structure.
I'll check and reevaluate that part of the ui
lele IW3HMH
Posted: 11 Sep 2014, 15:52
VK7XX wrote:When you double click on a contact in the QSO Informatiuon (F7) or Recent QSO (F9) windows the Update QSO box opens. When you select the QSL Information tab, the layout of the boxes at the top is.........
John
Sorry but I disagree!
The sent, sent date, received and received date are stacked vertically for QSL, LOTW & Eqsl information
It therefore follows that the QSL sent via and received via should be ranged horizontally alongside the QSL information, not interrupting the column layout for Sent, Sent date, received & received date
Posted: 11 Sep 2014, 17:19
by CT1BXX
Terry permit me to come back to John's idea
It seems interesting, we are grouping the information, in one side for sent, ad in other for received
We can also to improve it a bit more....
Another interesting point that in glance we can have the information more easily, would be to have the labels "QSL" "LOW" EQSL" coloured according the the color we use for confirmed ( usually green)
When we have received QSL (paper) the label QSL should be green and others stay black, if we receive only LOTW , than LOTW label, should be green.
The sent Labels stay in black
What do you think?
