SOTA Ref field being cleared when QSO is edited
vk3il
Post by vk3il »
I suspect there may be a bug with the handling of the SOTA Ref field in the edit QSO window. If you save a QSO with a SOTA reference, it stores the reference OK. If you then edit the QSO in the edit single QSO window, change a non SOTA ref field and save the QSO, then the SOTA Ref field is cleared.
Looking at it a little further, when you edit a QSO with a SOTA Ref, the SOTA association and region fields are visible and correct, but the actual summit field is blank. I suspect the error may be in parsing the SOTA Ref field into the form fields ?
Thanks for a great program BTW - it's become my main log.
David.
VK3IL
Re: SOTA Ref field being cleared when QSO is edited
Hi David,
In fact our Beta team discovered this bug and it is fixed for the next release
vk3il
Post by vk3il »
OK, great. Thanks Terry.
