Can't select multiple records on the Recent QSOs tab
Posted: 18 Sep 2014, 14:20
by K3LAR
Neither the Shift key nor the Control key has any effect when I try to select multiple records. Suggestions?
Larry
Re: Can't select multiple records on the Recent QSOs tab
Posted: 18 Sep 2014, 15:22
by DF5WW
Hi Larry,
that´s normal. The "Recent QSO" showing the actual log and entries can only checked alone. B.t.w. there is a possibility to load up or updating on hamqth, hrdlog, qrz.com and eQSL but that is working only for one entry. So it does not make no sense to check multiple entries in the "Recent" window. For that we have the QSO manager if you like to make multiple updates or things like this. But know, also there uploading or updating to the online services also only possible for one entry.
If you need to loading up to LotW or eQSL a few contacts you have to use the "QSL tools"
Hope that helps you ...
Posted: 18 Sep 2014, 20:03
by K3LAR
Thanks, Juergen - that definitely helped. Have everything straightened out now.
Larry
