VK9AN
Posted: 20 Sep 2014, 17:09
by G0OFE
This call is active from VK9X, but it still doesnt map to that country in cluster spots?
How do I make Log4OM do so? I have the latest Special Calls database loaded.
Re: VK9AN
Posted: 20 Sep 2014, 17:37
by DF5WW
The latest Country File and Special Call DB update is from September 7th. It´s possible that the call is not included yet (activity starts at September 18th). Think Chuck will made an update if he reads your post ;) ;)
Re: VK9AN
Posted: 20 Sep 2014, 17:46
Have you updated the country file because it maps to Christmas Isl. for me in the cluster
Re: VK9AN
Posted: 20 Sep 2014, 17:48
by K7PT
The VK9AN is in the SCL if you the latest update. Starts Sept 18th and is active.
Always make sure your using the latest SCL and Country file. :lol:
Re: VK9AN
Posted: 20 Sep 2014, 17:54
by G0OFE
Thanks.
I did update both files and restarted the progam earlier before my oroginal post, still didnt map correctly.
Just repeated the action after seeing the replies and now it does map correctly when I enter the call in the log, but been no cluster spots since.
Re: VK9AN
Posted: 20 Sep 2014, 18:15
G0OFE wrote:Thanks.
Don't forget you can use the spot simulator in the Cluster F3 window to test spots without actually sending them to the cluster on line, this saves embarrassment and cluttering clusters with invalid testing of spots
Re: VK9AN
Posted: 20 Sep 2014, 19:15
by G0OFE
Thanks Terry - forgot about that !
