counting deleted DXCC
DK5EW
Post by DK5EW »
Is there a setup at the import of a ADIF to count deleted DXCC's ?
73's Erwin/DK5EW
Re: counting deleted DXCC
If you don't check the box to update the countries in the ADIF being imported it will be imported with all deleted entities preserved and then the Log4om statistics will provide these deleted entities in the listings if you set it to do so
DK5EW
Post by DK5EW »
Terry,
I checked the box BUT I found now a way:
- statistic and awards
- DXCC and select your band
- below is "actions"
- select there "show deleted"
That works for me.
73's Erwin/DK5EW
That's correct Erin but by checking the box on import some QSO' with deleted entities will have had their DXCC changed
Best advice is start again with a new logbook and import the ADIF without the box checked that way you will retain all of the deleted entries that you have worked
Log4OM checks QSO date and use DELETED countries if the Callsign belonged to a deleted country at the QSO date.
If you enable the "update country" flag this should be mantained.
if you have issues on some QSO that changes country to the most recent one, even if made in older days, please report to us (and mainly to Chuck) for the necessary changes to country file.
