K1EL
Posted: 21 Oct 2014, 13:04
by F4BPO
Hi Daniele,
Very well done for this it is working perfectly after 5 minutes of test.
But it seems that in order to use F1 / F2 / F3 and so on for the macros the window needs to be on top.
Can we expect at some point that straight from the main window we can use shortcuts such as alt + F1 / alt + F2 or ctrl + F1 / ctrl + F2 in order not to need this window opened ?
That is anyway very good but I hope in the future we can use the main window and use shortcuts from there directly like in Win Test for example.
Thanks a lot for your great job !!
By the way I am using MicroHam Micro Keyer II as K1EL.
Re: K1EL
Posted: 21 Oct 2014, 13:23
I think it could be possible, but i need to check more deeply in the code if i can find an "elegant" way to do that.
Re: K1EL
Posted: 21 Oct 2014, 13:30
Why do you want the function keys in the main interface when you can log directly from the Winkeyer window?
I just run the Winkeyer window alongside the main window
Re: K1EL
Posted: 21 Oct 2014, 17:47
by F4BPO
Dear Terry,
Let me take a simple example or two.
- You are trying to work a new one such as TX7G thus sending a F1 from keyer window to send your call to bust the pile up and at the same time you have to go back and forth between main window and the K1EL window cause you are updating the IOTA reference or the QSL status as you want to put this contact as "required" in QSL sent or adding a comment while TX7G is sending a CQ call as soon as he finishes you want to click F1 to send your call but you have first to click on the K1EL window for your call to go through the radio
- Same as above and you want to look his QRZ.com page in Log4OM once again you cannot forget to click the K1EL to send your call and go back to main window to scroll down his qrz page while he is working another station, once he has finished you need again to click the K1EL window send your call and so on...
