Page 1 of 2
Upload error QRZ.com 1.19.0.0
Posted: 27 Oct 2014, 16:38
by pu5rht
Hi firends. Congratulations for the new version. The QRZ upload is not working for me, looking in the forum i see the topic about qrz.com problem, but in other version.
I turn the debug mode on and the log is:
Code: Select all
2014-10-27 14:25:46.8219 INFO: QrzComUpload: UPLOAD begin upload QSO to QRZ.COM Call: N4OX Date: 20141026 Time: 222322 Band: 10m Mode: SSB
2014-10-27 14:25:46.8279 INFO: AdifManagement: Begin export single QSO to ADIF string
2014-10-27 14:25:46.8329 INFO: AdifManagement: Export QSO to ADIF file completed
2014-10-27 14:25:47.2939 INFO: QrzComUpload: STATUS=AUTH&REASON=user is unauthorized
2014-10-27 14:25:47.4109 DEBUG: SQLiteDatabaseManagement: InsertUpdateDatabase Command issued
Thank you for help me!
73!
Re: Upload error QRZ.com 1.19.0.0
Posted: 27 Oct 2014, 16:43
"User is unauthorised" would indicate either a bad user name, password or nickname
Please check and re check that these are not only correct but in the correct case
Posted: 27 Oct 2014, 16:57
by pu5rht
Thank you Terry. So fast answer. The QRZ.com upload uses the API key, I recheck the key and it's correct. Can be a problem at QRZ.com site?
The adif upload from the site is working well.
73! - PU5RHT
Posted: 27 Oct 2014, 17:12
Sorry I thought you were referring to eQSL because we have already found the answer to the QRZ issue as reported elsewhere on this forum.
The answer from QRZ was
Hi Hi Terry,
Yes, this was always the case: the API is a XML Subscriber feature.
Unfortunately, a small bug was identified that was allowing some non-subscriber-users access.
We've repaired the bug, and now ALL non-subscribers no longer have access via the API.
Alex M. Tarsha, N0AMT
Web/IT Engineer, QRZ.comTerry,
I see that you are only a Ham member of QRZ and not a paid subscriber so the API upload is not available for you from any external software like Log4om
Posted: 27 Oct 2014, 17:23
by pu5rht
I'm so very much sorry Terry! I didn't know it my dear. I'm a free user of QRZ. Thanks a lot!
I'm going to wait for a lot of contacts and upload the adif file by site.
Thank you again and sorry.
All the best for you!
Roberto - PU5RHT
Posted: 27 Oct 2014, 20:20
I wonder why they're "forcing" users to subscribe for that service... 30 USD for selling data provided and mantained by customers itself is not enough? Mah...
Posted: 27 Oct 2014, 20:34
IW3HMH wrote:I wonder why they're "forcing" users to subscribe for that service... 30 USD for selling data provided and mantained by customers itself is not enough? Mah...
Even more of a puzzle is why there is an API code available in the Ham members settings screen if they can't use it!
Posted: 11 Nov 2014, 23:27
by N5INP
Hah I've just been trying this for the first time today and it wasn't working. But I searched for the answer here (aren't you proud of me) and found this thread. Yea, why give me an API Key in the first place if it won't work for non-subscribers!
Posted: 30 Jan 2015, 14:50
by F4BPO
Deqr Terry, Daniele,
I have tried this also (upload to QRZ) and it is also not working for me.
Log is showing
2015-01-30 21:48:34.7196 INFO: QrzComUpload: STATUS=FAIL&REASON=QRZ Internal Error: Unable to add QSO to database
Any news about that ?
Posted: 30 Jan 2015, 15:29
HS0ZLE wrote:Deqr Terry, Daniele,
Log is showing
This seems to indicate a QRZ problem at their end, I have the same issue here
I have written to Alex Tarsha at QRZ about this
