Those informations will be used for Log4OM V2
Actual Log4OM supports 1024 x 600, i reserve myself choice to choose an higher "minimum resolution" if needed, following also your needs.
Please report minimum resolution that you're CURRENTLY using on device that are CURRENTLY in use and you have plans to mantain operative.
I'm not interested in the minimum resolution of your ultramobile PC with Windows 95 and a zero A/h battery
