LOTW Support
Posted: 20 Nov 2014, 21:08
by NO7DE
Am a new user and am trying to set up the automatic LOTW post. I have not had any luck. The form is simple and I have set up the QRZ Interface with successful results. Is there any help with this
I have instantiated my user ID no7de,
Password,
Executable path (Copied that from the properties for TSQL8 program),
Station ID home (copied from TSQL8 PROGRAM)
TQSL private pass blank -- as I don't know what that is
Temporary path C:\HamRadio\Log4OM\lotw I just added lotw directory -- I do not use it
It says that user must have registered for eQSL, HRDLog.net, Clublog, HamQTH, QRZ.comand have LOTW Trusted QSL version1.13 or later installed for these automatic uploads to function. I have not registered with eqsl or hrdlog or clublog but am registered with LOTW v2.0.3 Any Help will be appreciated
John
NO7DE
Re: LOTW Support
Posted: 20 Nov 2014, 22:13
What is the station I'd?
Re: LOTW Support
Posted: 21 Nov 2014, 01:12
by NO7DE
station id is "home" as per my tqsl program
Re: LOTW Support
Posted: 21 Nov 2014, 06:10
by DF5WW
LotW and automatic uploads ??? There is only the way to up-/download from LotW via the QSL Manager by marking the contacts which should be uploaded and pressing the "Arrow up" button. The "Arrow down" is for downloading from LotW and works without marking any contact. By first use the date have to be set to the first QSO date in the Log after that the download use the date from last download ....
B.t.w. The "Private Pass" is the password for your LotW Keyfile if you have set a Private Pass for it. If not it can be blank ....
Aotomatic uploads working only for clublog, eQSL, qrz.com logbook if a xml subscriber, hrdlog.net and ham qth ... no automatted LotW up-/download :!:
