Page 1 of 2
WCA
Posted: 30 Dec 2014, 18:15
by CR7AHA
Hi
Can you update the awards, WCA doesn't appear in the list.
Best regards, 73
João Areias - CR7AHA
Re: WCA
Posted: 30 Dec 2014, 19:01
You can construct the award yourself if you have the list of the worlds castles and a copy of the award rules by using the award manager provided
Re: WCA
Posted: 02 Jan 2015, 10:02
by CR7AHA
Ok
But the list it's a long list, don't exist another away too do this?
Re: WCA
Posted: 02 Jan 2015, 10:37
Obtain the list from the award organiser as a spreadsheet or CSV file, then you can format that file and import it using the facility provided in the award manager - see the user guide for instructions
Alternatively when you have obtained the list send it to Claus our awards coordinator and ask him nicely if he will do it for you
Re: WCA
Posted: 09 Jan 2015, 12:37
by K7PT
The WCA xml file has been generated and there has been a problem up loading possibly due to the file size of 32MB.
We will take a look at what the issue is and try to resolve it shortly.
Re: WCA
Posted: 09 Jan 2015, 12:52
Attached is the WCA award
1. Unzip the file
2. In the Log4OM award manager (Utilities/award manager) click the "File" menu at the top left corner
3. select "Import award from xml" and select the file that you unzipped earlier - Click open
4.close the Award manager window
5. Open the award manager window again and check the "World_Castles: Worked World castles Award" is in the list
You are now ready to start working and recording the WCA award
Thanks to Chuck for his hard work in compiling this award
Re: WCA
Posted: 10 Jan 2015, 08:37
by DF5WW
Checked that way and import works fine for me ....
A big thank´s to Chuck too for his work
Re: WCA
Posted: 12 Jan 2015, 09:47
Added WCA also on main software update functions.
Unfortunately it's complicated to upload to website (because of his big size) so our award manager should pass file to me for updates
Re: WCA
Posted: 05 Aug 2015, 15:13
by yt9tp
WCA award needs to be updated.
Re: WCA
Posted: 05 Aug 2015, 18:59
I'll ask Claus to check that.
In the meanwhile there is an "useable" reference list somewhere that could be used? This could greatly improve our responsiveness in awards management (Claus is handling an huge amount of awards!)
