Hi All
My PC powered off last night after I shut down Log4OM, I turned the power off by accident,
Today when I go to start Log4OM I get the configuration screen as a new user, my setup is not in the drop down list,
If I enter my call and locator as a minimum and click save none of my qso's are in the log,
How can I restore the log ???
Trevor
EI2GLB
Lost my info and config
Re: Program has lost my info
Happy New Year!
You should have a backup log located where you told Log4OM to store it. It will be a ADIF file. Find it and then import it.
Happy new Year to you too,
I found my SQL lite database but I want to get the config file back too, would that be stored somewhere as well,
Trevor
Trevor
Trevor
The config backup is stored with the ADIF backup and will have the same date, see screen shot
The normal location for backups is C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\Backup
Rename the file config.xml and copy it to your config folder letting it overwrite the new config that has been placed there
- Capture.JPG (14.37 KiB) Viewed 4837 times
Hi Terry
Thanks had to step a few days back to get it working but all seems ok again,
Wonder what went wrong??
Happy new year to you and thanks again for the help.
Trevor
Trevor
EI2GLB wrote:Hi Terry
where is my config folder ???
Trevor
Thanks Terry I found it after I posted the first message you got in before I managed to edit it,
G4POP wrote:EI2GLB wrote:Hi Terry
Trevor
HELP MENU -> OPEN CONFIG FOLDER...G4POP wrote:C:\Users\YOUR USER NAME\AppData\Roaming\LogOMEI2GLB wrote:Hi Terry
Trevor
just in case you have a portable version or hardly redirected your config folder tampering the application.config file
