Dear colleagues,
Best regards.
In case you are working with the rotator function within Log4OM(PSTRotator) and in case you got in same tower 2 antennas with 90º offset, could you please let me know how you make it work properly?
In case the above situation is not yours, but you are working with the rotator function, could you please share your experience with your system
Many thanks for your help.
Rotator function
Re: Rotator function
something like a +- offset?
i remember something like that... i'm sending frequency to pstrotator, if i remember well...
is there an option on pstrotator to add an offset using frequency as choice parameter?
Hi Daniele,IW3HMH wrote:something like a +- offset?
I have exchanged some emails with Codrut from PstRotator, and in fact it has the possibility to handle the offset difference based on frequency.
It has also a very good option is to command remotely and antenna switch by information coming from Log4Om and also from Omnirig, so the problem is solved.
Because of that I have already registered my PST Rotator in order to make it work, now I am waiting for the Kit from DF9GR easy-rotor-control, and I will have the stations working as I would like he he he
73 Manuel Fernando CT1BXX
http://m0pkz.blogspot.co.uk/2013_12_01_archive.html
Using without prob
with kenpro kr-400 pstrotator and Easy-Rotor-Control (ERC) http://easy-rotor-control.com/
Kes.
Using without prob
Kes.
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
