Services Not Running Under 1.12.10
Posted: 12 May 2013, 14:05
by WE1X
I just upgraded to v. 1.12.1.0. All seems to be working fine with the exception of "Services". When I click on the "Start" icon under the Services tab nothing happens. My Comm Services indicator remains yellow.
Also a brief explanation of the External Software Start under the Settings 2 tab would help. It seems some of the settings that were under the Services tab for the previous version have been moved to this tab.
thanks...Harry WE1X
Re: Services Not Running Under 1.12.10
Posted: 12 May 2013, 14:38
Hi Harry,
when you start services you should see a small program starting with Log4Om, called Log4OM Communicator (you can see it on the systray too).
It should start automatically when you start services and if you check the AUTO RUN it will execute on program start.
This program should be started (if not) pressing the START button on his main interface.
All "services" are moved here. The program will communicate with Log4OM using web services and receives "fast updates" via a dedicated TCP connection.
If you cannot see the communicator running (in the task bar or in the systray) pse write here.
External software start is used to automatically start software companions with Log4OM.
For example you can start fldigi, external cluster software or other applications. You can start them before Log4OM starts it's "communications" with external sources or just after.
For example if you have a cluster software, you need to have it started before log4om searching for it, so check the "launch before" checkbox and add some delay after it's start to let services go up and running before log4om takes control back.
Daniele
Posted: 12 May 2013, 18:43
by G4VIW
I have the same problem as Harry and have follow your advice but without success. The communicator fails to run when I press start.
BTW congratulations and thanks for another fine update to Log4OM.
Andy
G4VIW
Posted: 12 May 2013, 20:45
Hi guys, in order to investigate the issue we need the application log.
in the HELP menu you can open the log file. The communicator log resides in the same folder.
Please open log4om, reproduce the issue then get those logs and mail them to a team member (or directly to me)
Daniele
Posted: 12 May 2013, 23:06
Please ensure that you are running Log4OM with administrator privileges, if you are not then the communicator will not function.
Page 18 of the user guider refers
Posted: 13 May 2013, 19:22
Andy G4VIW contacted me direct and sure enough the program was not running with Administrator privileges once we changed the Windows settings all worked fine.
I will add a how to for the windows Privilege settings to the user guide
Posted: 22 Aug 2013, 08:54
by M6GBT
I am running XP Pro with SP3 Log4OMcommunicator closes when I click on inbound. Page 16 of the manual shows how to get Admin privileges for win 7 32 & 64 bits, I have tried running this as Admin but communicator still closes any suggestions?
Pete
Posted: 22 Aug 2013, 15:18
Hi Pete, it seems like something was wrong on install. Please try:
1) uninstall and reinstall
2) open program, try to reproduce the error then get the log4om log file and the log4om communicator log file (both are in the \log folder of the settings folder, reachable by opening help menu and clicking on the last option).
Please remember that the log is cleared at every program start, so if you run program and the program crashes, get the log before restarting the program or i will not see the issue reported.
Send log file to iw3hmh (at) pisto (dot) it
By the way: The current release is 1.15 !!!
