I have found the instructions for the proceedure in the manual and have printed them. Do the instructions include the passwords that one originally entered in Log4OM settings > external logs tab? I only ask as some programs require this info to be re-entered even after a 'full' migration of data.
TIA
Transferring config to another computer
Re: Transferring config to another computer
Just copy the contents of the C:\............\appdata\roaming\logom folder to the same folder on the other machine and everything including passwords will be replicated
That's champion Terry.
Cheers
Guy
Cheers
Guy
Same as here: http://www.pisto.it/forum/viewtopic.php?f=6&t=1401
There you´ll find also the way how to transfer your log to another machine
Thanks for the additional info, Juergen
