Upploading 1.20.0 without result.
SM5MEK
Post by SM5MEK »
I am trying to uppload the new 1.20 and it seems that i get the codes but when i should unpack it pc says the program dont exist. ? Tryed several times with same "no program".
What to do? 1.19 is working good so i will continue with that so far.
SM5MEK. :?
Re: Upploading 1.20.0 without result.
Hi Jenny,
i think you mean you´ve tried to download the V1.20 ??? Have checked that out and download and unpacking working perfectly. Think there should be a problem with your internet connection if the download not works for you at the moment. Have tried to attach the unpacked setup file to an email but my provider allows only attached files with max. 10 MB :( :(
So please try again later on to download here: http://www.pisto.it/wordpress/wp-conten ... .php?id=53
72´s to a QRPC member :D :D
Jenny,
Did you resolve your unzip problem?
