Dear friends, My OS is Win 7 32bit prof. and during installation I get the message:
Error opening file:
c:\users\user\appdata\roaming\logom\log4om_enu.pdf
the system cannot find the path specified
Is there any method for curing the problem?
Thanks 73.
Installation problem
- log.jpg (118.41 KiB) Viewed 2841 times
Re: Installation problem
Just click cancel then during the instal deselect the user guide choice now it will install ok, but don't forget that you must instal as the Administator.
You can download the user guide at some later time from the help menu
It worked, thank you very much 73.
